LS2* Cant change titles here I guess.
First attempt at tuning, so I'm definitely green. Have read a hundred different threads here, watched every you tube video I could find, and have taken a crack at it.
Bought this c6 ls2 with a btr stage 3 cam, se long tubes / x pipe, and an aftermarket "cold air" intake.. The cam / headers were installed by a reputable shop, and tuned by same said shop (2005 c6 Base as found.hpt). Previous owner installed the cai some time after this, and then I got the car.
Immediately after getting the car home and doing some spirited driving, I started getting P0131/P0151 codes which tipped me off to a lean condition. Tested for vaccum leaks and found nothing. Tested fuel pressure, and it is fine, so assumed it was a tuning issue related to the change from stock intake system tha thte car was tuned on to the aftermarket system.
So I picked up a used mpvi2 and started logging. The lean condition seemed confirmed by high LTFTs. I started by tuning the MAF using LTFT+STFT error ratio, but decided I should pick up a wideband.
So now I have done several rounds of MAF tuning with the wideband, and have it dialed in quite well in my opinion (See 2005 c6 MAF Tuning AFE Intake 5.hpl).
I've copied the MAF cal tables back over to the "base" tune that came with the car, and dynamic airflow for now until I have a chance to dial in the VE table. (MAF Calibrated AFE SD Disabled.hpt). The car is idling terribly at startup if I have dynamic enabled after correctly tuning the MAF, so I figured I would run MAF only for now until I dial in the VE table.
To my rookie eyes, the EQ Ratio seems to trend consistently higher than Commanded EQ Ratio while cruising around after flashing this tune (MAF Calibrated AFE SD Disabled Cruise.hpl). Is this normal? To me I would expect to see it averaging at commanded EQ Ratio like I do in my MAF calibration datalogs. The "final" tune seems to oscillate a lot rather than staying flat which also leads me to believe something is wrong.
If this is not normal, any hints as to how to dial this down to be inline?
Thanks!
Attachment 160996
Attachment 160993
Attachment 160994
Attachment 160995
