Clutch switch input for cruise control
I have a gen 3 LS with a manual trans. Its DBW LQ9. I am trying to get the cruise control working. I see the "cruise on" and "set/coast" inputs change correctly in the log. I have confirmed 12v to pin 33 of the blue connector of the ECM that goes to 0v when the brake pedal is pressed. I also have 12v to pin 6 of the TAC module when then brakes are pressed and 0v when the pedal is released. This is through a changeover relay that grounds the line when the brake pedal is not pressed. I have read a lot about the issues with the brake inputs to the ECM and TAC module. I have not found any info on vehicle with manual transmissions. I am assuming the "torque converter clutch off" signal does not need to be seen when the vehicle has a manual transmission and is replaced by the clutch position switch signal. From what I can tell they are the same signal (12v present, 0V when pedal is pressed). I connected that signal to the blue connector pin 33 and tested and I cannot get the cruise control lockout to read "no". I have tried it multiple times over 45 mph.
Any help you can provide will be greatly appreciated.
Thank You
