5 Attachment(s)
Cammed 5.3L high idle and cruise control issues
First time tuning, from a cold start the truck runs great and idles great until you shut it off and restart, then the idle goes through the roof on cold start and back down and basically runs 35 mph on cruise control until you brake enough to force it to idle down. If you blip the throttle in the slightest it shoots to 2200 rpm. Attached is a long first drive log and then a second log after the restart along with the tune and config file. Any help reviewing will be appreciated.
Engine Specs:
5.3L Summit Long Block ATK Performance
Summit Pro LS Cam .550 Lift 222/232 duration, 112 degrees lobe sep
TBSS Intake
Nick Williams 92mm DBC TB
Dougs 2 7/8 Longtube Headers 3? collectors
3 inch exhaust with x pipe and SpinTech Sportsman 3000xlp mufflers
4L60E w 3200 stall
3:73 Rear Axle
Attachment 161199
