Core ecu lost fuel pump prime signal!
hello everyone, I went to start my car and when I turned the key my fuel pump did not prime... I immediately thought that was odd. when I tried to start the car it just cranked. I checked the fuses they were good also checked the relay and got a strong click when I applied power and ground directly to pins 85 and 86. I swapped the fuel pump and ignition relay and had the same results, the ignition relay clicks when keyed on but fuel pump relay does nothing. I wrote another tune to the ecu and it does not prime the fuel pump after the write is complete like it use to do! When direct power is applied to my fuel pump it does run! I have confirmed there isn't a 12v signal coming from the fuel pump signal wire during the initial pump prime period or when cranking but I can connect to the ecu and see live data with no DTC's recorded. Has anyone had this issue or have any ideas of things to check before i give up on this system?
fuel pump has no prime or run
Quote:
Originally Posted by
gtstorey
Have you put a voltmeter to the wire at the ecu to confirm no voltage? Or better yet, an incandescent light bulb to confirm current capacity?
hello, yes I used a voltmeter to verify no voltage at the ecu, I also used a simple test light and the wire is dead. I have narrowed it down to connector C pin#3 I think this wire supplies a ground to the fuel pump relay. If I back probe this wire and send it a ground, the fuel pump primes. I'm going to do some more test today and try to get it running.
