2 Attachment(s)
Mystery Idle Misfire L83 Stg 2 cam
Hello all,
I am looking for a little guidance for trouble shooting a potential problem. I have been trying to hunt this issue down and I am running out of ideas and I am hoping some people with way more experience can chime in.
Breakdown of the truck
2014 Chevy Silverado 5.3l
- 6.2 intake and throttle body
- MSD Spark plug wires
- NGK rhodium Spark Plugs
- BTR l83 Stage 2 v2 Cam
- BTR 5.3 GEN V TRUCK CAM KIT - 2241023116R1
- BTR .550" LIFT GEN V LT BEEHIVE VALVE SPRING SET - LIKE 12691120 - BTR91120-16
- BTR VALVE SEAL SET
- BTR CHROMOLY ONE-PIECE PUSHRODS - 7.850" LONG - 11/32" DIAMETER - .080" WALL
- BTR GEN V LT VVT PHASER LIMITER - 4 DEGREES - BTR-VVT-GENV-4CAM
- BTR CAM RETAINER PLATE - LIKE 12589016 - BTR89016
- CBI STREETCARS DOD CONVERSION PLUG SET - GEN IV/V - CBI/OBO
- BTR GEN V LT HEAD BOLTS - COMPLETE SET - BTR/LT1/HBK
- BTR GEN V L83 HEAD GASKETS
- CHEVROLET PERFORMANCE HEADER GASKET - GEN V - 12657093
- DELPHI HYDRAULIC LIFTER SET - GEN V - X17120735
- BRIAN TOOLEY RACING LIFTER TRAYS - SET OF 4 - BTR95365
- Chevrolet Performance Balancer Bolt for Gen V LT Engines - 11547372
- BTR GEN V VALVE COVER GASKET - BTR-19787
- BTR GEN V VALLEY COVER GASKET - BTR-23104
- BTR GEN V LT CAM BOLT - LIKE 12681018 - BTR-81018
- BTR CAM RETAINER BOLTS - BTR61455-4
- SPEED ENGINEERING 2014+ SILVERADO & SIERRA 1 7/8 LONGTUBE HEADERS - 25-1037
- SPEED ENGINEERING Y PIPE - 2014-2019 SILVERADO/SIERRA - 25-1038
- New Intake and exhaust valves
- New oil pump
- New timing gears and chain/tensioner
- K&N catch Can
- K&N CAI
- MBRP single 3.5" exhaust
- rebuilt 6l80 with circle d stage 3 kit
- new circle d Pro 300mm torque converter
- multiple sonnax upgrades as well
I have been working with a tuner for almost the past year. It wasnt until late last year that I started experiencing problems. The initial issue was will cruising at hwy speed the torque converter would unlock and relock almost as if you were to hit a deep crack in the road. Long story short I believe this issue was a coil going bad and shortly after I ended up replacing all of the coils with new NGK round coil packs. Since finding this issue the tuner has had me add misfire tables to the logs. While I believe part of the issue is resolved as you can see in the log the cylinder 1 misfire amount is rather high. Now I do understand that the scanner may see a misfire on 1 and it could really be a different cylinder. So in hunt for more clarity into the issue for a hopeful resolution I have tried to fix whatever might be causing this issue.
First thought was bad plug
bought a whole new set same kind- issue still exists.
swap plug wires around and still nothing changed
checked compression and all were with in 10%, on the closer to outliers I did a leak down to confirm, all less than 5% loss
Changed to all new 6.2 injectors, compression and leakdown again with no change
changed to a new high pressure fuel pump- still no change
changed to new 02 sensors - still no change
new maf sensor - still no change
new map sensor - still no change
new evap - still no change
checked grounds and added additional/better cables
I have hunted throughout this forum and have adjusted many things and although some have helped a little none have truly changed much of anything.
I am hoping some one some where that has some experience in tuning these trucks can help get me pointed in the right direction, or possibly all of this is normal.
Things I haved considered but not done yet would be changing the thermostat, coolant temp sensor. Attachment 161390
Attachment 161391
