Question about reading a tune then writing back
I have a 2008 Dodge Ram 6.7 cummins, all emissions on. Currently running an Edge tune.
I just replaced the intake with a Banks Monster ram, and relocated the Grid heater to the air horn. I am now running into a P2609 code because the new grid heater is only pulling 60 amps as apposed to the 150-200 amps the stock grid heater pulls. I have a MPVI3 that I used for the transmission tune, and I found the code in the .hpt to turn that code off, but I have been told that pulling a file that has a tune on it, you should not write it back since there may be PIDs that are not seen and it would not be clean. I thought I would ask here, since the source that told me that is not an expert. The file I pulled with the tune seems to be readable, and I see where they made the changes to the timing fueling and such. Just dont want to mess up my truck. I am using the 60HP tune.
If this does not work, I will try to build my own tune, just a learning curve to get started ;).
Any advise from the community would be much appreciated.
Thank you
