LM7 5300 swap into Jeep Wrangler
I bought a Jeep Wrangler with an LM7 5300 GM engine swap and I have an intermittent issue.
CURRENT ISSUE: Most of the time no start (no fuel, I believe this is a SKIM issue).
HISTORY: Ran fine when I got it but wiring quickly became a mess and I had to fix a bunch of shorts, ground, etc and removed the alarm which was causing issues.
This is when the SKIM issue started, I read into VCM editor, enabled SKIM and wrote it. The engine ran great, Finished fixing wiring issues and drove it around a while (maybe 40 miles).
Now it's having the issue again, I went to delete the SKIM and when I read into VCM editor The vehicle pulled up as a GM5.3 with a different VIN instead of the Jeep Wrangler and the correct Jeep VIN. Also all different tuning options under every category but not SKIM and VAT is disabled (also I don't have a license for this GM VIN).
Every now and then when I leave the battery disconnected and reconnect it, the Jeep will run fine.
Maybe I fixed something in the wiring and now it's reading from the GM5.2 PCM for the engine and not the Jeep Wrangler ECU?
I am thinking I will try tomorrow to see if I can't just unplug the GM PCM and then read/write the Jeep with the SKIM disabled.
Are there any other recommendations that I might be able to try.
On top of it, there is a Crankshaft Position Sensor correcting unit wiring into the Jeep ECU. It seems excessive to have a Jeep ECU, GM PCM and a CPS unit, it's there a more simple option?
