LSX376 timing / knock sensor tuning
Hello!
I've recently swapped out my L92 (Aluminum 6.2, 10.5:1, VVT Truck cam) with an LSX376-B8 (LSX Bowtie Iron block 6.2, 9:1, LS3 cam).
My goal for the build was to put together a super reliable, lazy, low compression motor that can run on any fuel I dump into it (Think South American villages where the "Gas Station" is a bunch of sketchy 2-liter bottles on a picnic table on the side of the road.)
I'm running a pretty stock L92 based tune, and have the truck running well.
- MAF tuning
- MAP Tuning
- VVT Disabled
- Torque management dialed down
- Trans parameters tweaked
- LTFT's +/- 1.5 degrees
- Zero KR, towing on 87 Octane (Just completed a 6,000 mile round trip, weighed in at 10,500 lbs with the trailer)
One thing that I haven't touched at all from the stock truck tune is the timing tables and knock detection parameters.
I'm wondering if there are any Knock detection parameters that should be changed when moving from an Aluminum to an Iron block. I don't expect this setup to be into knock with the low compression, but I'm skeptical that there's truly ZERO knock. I've only seen a small blip of 0.1 a couple times, when accelerating hard through a downshift. I want to make sure the system is functioning as intended.
I'm planning to swap my timing tables over to an LS3 based table, instead of the truck table, which looks a bit more aggressive.
-Rob
