Originally Posted by
gametech
For some reason, when I flash a "calibration only" write to my car it usually remembers the last alcohol percentage from before the new flash. However, sometimes it goes to 0% and has to relearn its way back. The pcm in question is in a 2004 GTO that had a flex fuel patch added via other software before converting to an HPT 2bar sd OS. It has a content sensor in the feed line just before the rails and the appropriate wiring so that it works. I could understand if it went back to a default setting, such as the 38% setting for if the sensor errors out, or if it always zeroed. I just have no idea why it occasionally (but not most of the time) loses the content percentage memory when flashed. While on the subject, it would be nice if HPT gave access to the update rate tables for that sensor, as it takes a few minutes to fully update after filling up with a different E percentage. I have other ways of adjusting that, but it is a minor nuisance having to use multiple types of editing software because of all the tables HPT does not have.
