2 Attachment(s)
C6 with a low RPM surging issue
Attachment 162709 Attachment 162710
I have a 2012 procharged C6 corvette with an E38 and LS3 with a M6. Cam is a 230/250 116 and has about 8 degrees of overlap. When I bought the car a few months ago, it was tuned MAF only and had some drivability issues. Car ran very rich everywhere and had a low RPM surge. I went to a 2 BAR OS thinking the cam may not be behaving well with the MAF at low RPM. I'm a novice tuner so its been a steep learning curve but its slowly coming together. The issue I?m having is that I have a buck or surge at light throttle from 1000 to 1500 RPM. Doesn?t matter if the engine is hot or cold or what speed I?m at. The surging is much more pronounced in lower gears but is noticeable all gears. On occasion, at low speeds like creeping through a parking lot, the car will surge bad enough that I have to feather the clutch to get it to settle down. Being that my fueling in that area is very close, I?m struggling to figure this out. I have pulled several degrees of timing in that area, at roughly 3 degrees each time and the surging has gotten a little better but its still there. I'm just not sure how much more timing I can continue to pull or even if that's the best approach. Would you guys happen to have any suggestions?
