Originally Posted by
twenglish1
Were you adjusting the VE without the MAF properly disabled? There is a pending P0102 code, so there is something going on with the MAF. However none of the steps were taken to ensure it was forced into SD mode. You also need to copy the corresponding rows of the primary VE into the Secondary VE after making changes to the primary on this OS, it defaults to secondary VE with a failed MAF. If you are running fixed 58psi fuel pressure your injector data is wrong, it is setup for a vac referenced pressure regulator. As stated above, try again, get your injector data setup right first before making any changes.
