Originally Posted by
02Vette
Hello all, my tuner just completed a tune this morning on my brand new GM Crate motor. He has been tuning my car for a while now on different motors. So, I have complete trust in him. The issue I am having is we keep getting Crank Sensor codes, and the car jerks and bucks. I purchased the Lingenfelter 58x to 24x box prior to motor installation and installed it with the motor. It is installed correctly, with everything routed away from heat, coils and spark plug wires. I am pretty methodical and followed the instructions to a "T". I even called Ling., to verify, but did not get much help. Basically they said if the box is lighting up the way it is supposed to, then there is no problem with their box. I did ask even if it receives a good signal (indicated by the Green light), could it be sending a bad signal to my computer? He said yes, but then said no because it is lighting up Green.
I replaced the Crank Sensor that came with the motor with a new one from the parts store. Same issue... The new motor is a 58x, my car is a 24x. The motor I pulled out is a LS3 with a 24x wheel I had installed on the crank so I would not have to go through the Lingenfelter box, it worked flawlessly.
I have done some research on it, I have seen where the box has worked perfect for years for some, and some had issues. My tuner recommended replacing the box with a new one to rule out the current one. I understand what he is saying, and yes that is on my list of things to do. But, before I spend another $300.00+ again, I wanted to see if anyone else had this issue,or knew what to look for.
It is truly a plug and play system. I have the correct lights when I should, I am getting tach signal to my instrument panel. When idling, there is no issue. In neutral, we revved up to 3k and back down smoothly with no issues. We were able to get one 3k-6k pull, then it went back to the issues.
Is it possible the code I am getting is false, and it is really something else?
Has anyone seen this before? What was the issue/fix? Thanks.
