2 Attachment(s)
Need tuning help; surging issue. Thanks!!
Attachment 163064Attachment 163065
Well, I chose to be stubborn and tune my car myself. I have tried to do my research to the best of my abilities. However, I've been scratching my head with an issue for a while now, and can't seem to get it resolved. So I was hoping to get some insight here in case I am overlooking something.
Issue: When going from idle to part throttle, there is a rough transition. The car surges for a little and will sometimes stall if it surges too long, or sometimes the surging will stop if I get the car cruising. I have tried adjusting the BRAF, the VE, and my spark tables and have had no luck. So I'm not sure if this can get resolved in another table or if I am missing something entirely.
Other than this, I believe the car is fine; my AFR gauge (not logging on HP) is in the range where I want it. 14.2-14.7 cruising. I do also have PE disabled currently to avoid any further issues, and I plan to turn it back on once I'm over this surging issue.
Starting to think I chose the most difficult way to tune the car lol :shrug:
Build:
96 Camaro LS swapped
Gen 3 p01 0411 ECU
5.3 with factory harness (deleted MAF)
228/232 camshaft, 0.600" lift, 114LSA
243 heads with 1 7/8 headers
stock rotating assembly
ls6 injectors (#12564162)
th400 (removed all transmission inputs on editor)
102mm throttle body, DBC, Jegs sheet metal intake
no knock sensors (I am aware this is not optimal)
3 bar map
91 octane
