3 Attachment(s)
L29 0411 swapped, way leaner than commanded on cold starts
I've got a mostly stock L29, rebuilt by me a couple years ago. Shorty headers, no EGR, no Cats, 0280155884 22.2lb@4bar injectors from 5-0 motorsports. I'm tuning using an AEM UEGO 30-0300 wired into the EGR connector, using their supplied formula for AFR conversion (voltage*2.375)+7.3125. Running E10 fuel and a programmed Stoich of 14.17. On cold starts, it runs at 20-30% leaner than commanded AFR, as it warms up it gradually comes back down to +/- 2% over the warm up period. Its currently using MAF only, dynamic and LTFT/STFT disabled, as that's what I'm trying to get dialed in right now. I notice that if i use the command AFR function in the scanner, and try to command it richer, the actual AFR reading doesn't budge. I'm attaching two log files. One is of a complete cold start. The other is after 15min of rest, and an ECT of about 170f, where it does the same thing, just to a lesser extent.Attachment 163259Attachment 163260Attachment 163261
