trouble getting VE just right
Ok, I have spent a lot of time logging and tuning on my VE and it seems dead on while cruising and such (-6% or so) and my WOT pulls are good when I first reflash/zero fuel trims. But, as I drive, my 105kpa fuel trims start going -5 to -6 throughout the rpm's when I go WOT causing my WOT AFR to go leaner the more I drive. Why would it pull fuel at WOT like that? I thought it would zero out when it hits PE. Where do I look for fine tuning here? Do I just add to the 105kpa range of the VE?
Thanks in advance!
Joe
edit- I guess this would help- the car is an 05 GTO with an APS twin turbo setup and alky injection.
