new setting commanded afr
I plan on buying hptuners here shortly and am trying to figure out which one I should go with. I have a lc-1 with dynotune gauge for my wideband setup. From what I understand you can with (pro) log the afr and paste special multiply and its as simple as that. Is this right?
How would you go about doing this with standard and pro versions? Also can I leave the dynotune gauge hooked up and still log afr on the hpt scanner?
I have a 05 gto a4 that will be getting the tuning.
