any way to disable LTFT's at 105 kpa on an ls2?
Like the title says, I was wondering if I can disable the LTFT's at 105kpa? I am having issues tuning my TT ls2- no matter what I do with my VE, it always seems to carry a negative LTFT into the PE and lean out after a while of driving. I will go from 11.5 AFR to 12.5+ after driving for a while. I was thinking maybe max out the min map vs. baro at 105 kpa so it never enables LTFT's there- is that right?
My VE is kicking my butt too- I will get it where I think it is perfect, then it will be way out of whack again. I am going to try to play with it "maf only" and "disable" the VE to see if I can get it any better. Ugh, this is frustrating. I think it is making it worse since I am spraying a good amount of alky- it is making everything hard to dial in :(.
The only other thing I can think of (and it seemed to work "decent") is to disable the LTFT's all together, but I would prefer to keep them enabled- just not at 105 kpa :). Thanks!
Joe
