lc-1 hooked up is it right
I have finally hooked up my lc-1 as a wideband and a narrowband. I am attaching a few logs after I finished connecting everything. Thanks to soundengineer for his stickied posts on how to hook these things up.
Question #1 does it look like I have it hooked up right. It seems to look ok to me it's reading 14.7 and seems to look good.
Question #2 In shortride1 I forgot to attach the EIO connector to the MPVI pro and afr locked at 12.27. But when it was hooked up in shortride2 it seemed to be correcting it self to 14.7. Why would it lock when not plugged in and seem to be doing what it is suppose to be doing.
The car is still running in closed loop. I wasn't going to do speed density ve tuning till I had my wideband in. Also the battery was dead on the car after I got everything hooked up do to having the doors open for a few hours. When I set up the lc-1 with the voltage offset directions in the stickies. My volts are still set at 2.95 because I wanted someone to look at my scans and let me now if I set it up ok.
Attachment 5946
Attachment 5947
Attachment 5948
Thanks to everyone who looks at this and helps me in any way they can. I will try and answer any questions to the best of my ability which is very limited at this point.
