ok, where to now? KR owns me
I swapped out knock sensors tonight for the newer sensors, I'm running 100 octane in it, and I'm still getting a ton of knock. I get a little blip of knock when I start the car on occasion, I get knock when the convertor locks if I'm anywhere near moderate throttle, a little knock at WOT, and I get knock on acceleration with the convertor locked. I'm in the middle of SD tuning and my AFR isn't real bad I don't think. The log I did tonight doesn't look as good as it has previously but I think that's because the temp outside dropped 15 degrees over what it was last week. I'm seeing richer than usual afr error %. The ve I'm not overly concerned with right now because it's generally close enough to not be a problem. The knock is what I want to get taken care of. I'm pretty sure this is all false knock since the new sensor install and 100 octane made zero difference.
What next? What should I be doing now to confirm it's false and not a mechanical problem and if it is in fact false what should I do about desensitizing the sensors? Thanks for any an all help you guys can send my way. I feel like I'm taking the proper steps to rule out true KR but it's a big price to pay if I'm wrong.
I'll upload my current tune and log although the ve error went rich due to the cold weather we're having.
car and mods
98 f-body
228R cam
5.3L stage 2.5 heads
3500 stall
strange 3.73 rear
full exhaust and bolt ons
