Can someone check my tune?
I have a turbocharged 2005 Ecotec 2.2 Pontiac Sunfire, custom turbo kit, 42lb injectors, T3 Super 60 Turbo, .48ar exhaust turbine, 2.5" intercooled charge piping, HKS BOV.
I been reading alot and asked alot of questions, and alot of people here helped me out last year, and now i finally got the tune where i want it to be, i used to have the problem with cant go richer under boost, so i raised my VE offset from 20% to 33%, and now when im in full 8 PSI's of boost it is around 12 AFR, but im not sure if i suppose to change the VE offset or not.
I just want somebody who is really good at tuning look over my .hpt file to see if there is anything i did wrong or if there is something i should change, very appreciated! :D
I have 2 issues that im not so sure about:
First of all, sometimes when iim just cruising 50-60 mph on the highway, not in boost, and i have my foot slightly on the pedal, maybe about 10 TPS, and not changing the pedal position, all of a sudden the car lean out over 20AFR and the car shakes and sounds like if it is bogging out, and i tried to tap the gas pedal and give it some gas but it doesnt really work, so i have to wait like 5-10 seconds and then press on the gas again and everything is back to normal. What kind of problem is this? Is this my spark plugs or my injectors?
Second problem is that i have a lean spike right when i press the gas pedal a little, like if im pulling out of a driveway or a parking lot and i gas it slowly and it is in closed loop, but once i press the gas even 5% TPS, it jumps to around 18AFR, but then if i gas it more, like around 10% TPS, it doesnt spike like that, so i dont know if i should just ignore this problem or what?
But if someone can please help me out with my tune would be so awesome!
Thanks!
Race Tune.hpt file attached
