When will this be released?? Still waiting to finally get full tuning power over the Fords. Learnt my mistake by tuning blind and don't want to go through the same process again.
I would also like to know this. Thank you
Me too.
bump.....
Full scanner support is a needed for sure for the fords.
The HP scanner is in my opinion the best on the market, I'd really like to be able to use it though.
Currently using the next best scanner (SCT) is the only option here.
Any word on updating the sampling rate on the scanner for the Fords?
Any update on this would be greatly appreciated.
Mike
the sampling rate cannot be increased, our scanner is receiving data as fast as the PCM will send it. We are planning a system that will allow more effective scanning by using a priority system, we have no timeframe for this development as yet.
Chris...
I'm not all that concerned with the sampling rate, just with the actual scanner. Not being able to see knock retard is kind of scary.
+1 on the knock retard.
for sure we need it ,just we need the timeframe to know
Chris,
Do the scanner put the Ford into 6x CAN bus mode? DashDAQ does this and I'm able to data log 30 items with ease (far more than I can with SCT's).
You can log a ton of items, they just log slowly. I wonder if this mode you speak of would increase the speed as well?
anything on the 6x CAN bus mode? Maybe that would increase the speed?
