Wideband logging with PLX AFR-SM
Apparently I've done something wrong somewhere down the line because my wideband just sits at 15.3ish and doesn't move. I've followed the write up that has the pic of the AC pressure sensor wire shown at the top. I did go the EGR route though. ([PID.2811]/.5)+8.3 <-- this brought HP tuners closer to my gauge but it will obviously need changed since I'm having this problem.
My gauge fluctuates how I believe it should but apparently HP tuners isn't seeing any of it. EGR position fluctuates between 3.51 and 3.55 and that's about it. I'm really stumped on this one because I the wire that I'm tapping into for HP tuners to log is the same wire that feeds the gauge. BTW I'm using the PLX AFR-SM. I tapped into the Analog 0-5v output single wire plug. Is that wrong? I'm stumped.
