Is there a way to to get my 0-60 time and my quarter mile time through HP tuners? I know I can watch the time on the bottom but is there a easier way to do it. I apologies if this has been answered I didn't see anything with searching.
Not currently. 0-60 you could get an estimate by logging mph and then using the timer on the graph.
check out pro scan its an obd2 data log and reader its like 25 bucks i think and it has a pcm dyno and track
Plans yes, eta no.
This would be pretty cool.:cool:
0-60 is easy and accurate IMO with hpt
use chart display
get your 0-60 run all appearing on the screen with it paused
pull your vertical line until you find 60 and bring it to the verge of 59 to find exactly where it first hit 60
enter the elapsed scan time at the bottom in your calculator
now drag your vertical line over and find exactly where it went from 0 to 1 mph then subtract the elapsed scan time where it was last at 0 before showing movement
