Idle Airflow.AC Airflow - Ramp In / Ramp Out
I'm confused about the AC Airflow tables in the Idle Airflow section.
For the Ramp In table, the mouse over says "The idle airflow ramp in step size after the AC clutch releases" while the Ramp Out table says "The idle airflow ramp out step size after the AC clutch is applied".
I would expect that engaging the clutch ("clutch is applied") would require more air therefore a ramp in of air would be needed. This implies the opposite.
What am I missing here?
