i noticed there no on/off cot like for v8's...what have you guys done to counteract that?
there is supposed to be an enable temp, that appears to be broken. :banghead:
let me check it out.
Chris...
edit:
If you set the COT AFR higher than your PE (ie. 14.7 across the table) it should effectively disable it as well. As the PCM will always use the richest.
Regardless i will fix the enable temp.
When I set the A/F to 14.7 on the COT table the car wouldn't run. I set it to 12.7 where it dropped below 13 and it ran fine. Shaved two tenths off ET. A master on/off switch would be ideal though.
What does this do for you?
I concur,Quote:
Originally Posted by Little G
"Make it so" -picard
:huh2: i dont even really watch star trek..
ohh well.. add it to the features to add for the next release
wheres the im with stupid smiley when you need it :)Quote:
Originally Posted by Missing2
there is no master on/off switch in the code guys, the enable temp is the thing to use.
Quote:
Originally Posted by Chris@HPTuners
??? please give a clear explanation on how to do it then please :)
The V6 does not have temp control. All we have is AFR based on fuel flow. Either the temp control or the on/off would be nice.
the enable temp bug has been fixed, we will be making this available in 1.6 (or sooner if you email us your customer ID).
E-mail sent. Thanks.
