Drunken ECU Experimentation
I'm going to post this against my better judgement. Tonight I got a bit tipsy and thought it would be a good idea to try something out. I pulled the 2008 HHR GMPP tune out of the repository, and then proceeded to write it into my 2009 Cobalts PCM. Normally I wouldnt try this because I'd be afraid of bricking my PCM.
The drunken leap of faith + usage of 2 credits = the results look good. Lets hear it for liquid courage :yay: :chug:
Here are the details from my PCM before the flash:
http://www.ecimulti.org/scratch/HPTu...detail%201.jpg
http://www.ecimulti.org/scratch/HPTu...detail%202.jpg
And this is after:
As you can see all of the segments changed along with the OS ID. The key segment is #2 though, thats the P/N for 2008 HHR SS Stage 1 tune.
After the flash my RPD bliped and suddenly changed from 0psi to 2psi, which is obviously the result of the incorrect MAP sensor scaling. I then started the car, and voila it started nicely. Everything else in the car seemed to be working normally, which I expected since its also a Delta chassis.
I then logged the car, and what do you know the idle pre flash and post flash... the MAP and Boost Pressure sensor differe by about 30kPa, which is about right on for a .3 BAR difference. I've attached the logs of the car idling before and after flash.
So in closing, if I can ever get those 3 BAR MAP's from GM Parts Direct ... it appears I'll have a stage 1 to build a base from. It goes without saying you'd need to copy/paste all of your Cobalt centric tune stuff over.
This is good news since it appears GM raised the duty cycle of the solenoid in their tune, and so now the DAL should be much more potent :)
Tomorrow I'll drive around a bit to get the codes to pop for MAP sensor error and then flash back to the Cobalt tune. Obviously I'd prefer to get my hands on a real Cobalt stage tune, but the price on this was right... free.
