M6 to TH350, check my speedo calcs please
ACCIDENTLY POSTED THIS IN THE WRONG SECTION, MOD'S PLEASE DELETE
Getting ready to do a car that has an M6 to TH350 conversion. Just wanted to make sure i'm not missing anything in case I run into a suprise after attempting to correct the speedo.
Here are my calculated values to enter into the tune:
2002 Camaro SS
Tire Size: 275/40R17
Gear Ratio: 4.10
Tire Height: 25.7"
Installed Transmission speedometer drive gears are for a 3.31 gear ratio. The tailshaft gear has 9 teeth and the cable drive gear has 22 teeth = 2.44 ratio.
He is using a Dakota Digital pulse generator that produces 8 pulses per revolution.
VSS Pulses/Mile: 10550
Rev-Trans: 3.28
Final Drive Ratio: 4.10
Trans Revolutions/Mile: 3217.84
These calculations were made using the information provided by Chris at post #2 here:
http://www.hptuners.com/forum/showth...ght=vss+pulses
Look right?
