Having problems with tune with 80 pound siemens using Gregs Dvd.
I have Gregs Dvd so guess cant' post the tune . I was running on siemens 60s and the car was running like a dream,idle,decel ,etc all excellent.
Now ever since put in 80s with the value in his dvd things are all whacked. I am getting max short term trims both banks equal full negative. I have tried to lean it in ve and not having much luck just trying idle area first.
As said his 60 data worked perfect. But notice that in his dvd it says 80 cobra injectors. So are these the same as siemens 80s?
Anyone run his tables and have these problems with 80s. Anyone else even running 80s?
Also min pulsewidth is 1.1 ms and even smaller ones like 60s he says to go to .8ms where stock setttings are 1.27 So that 1.1 just seems wrong.
And he doesn't mention if supposed to change default pulse width to same as minimum pulse width.
I was thinkin mabye vacuum leak or something but don't think have one.
And it seems all these problems happened when installed the 80s. As said both banks are matching closely both ltrim or strim.So don't seem to be a problem on one side. And doubt both sides.
