Water Temp Gauge Reads Zero, PCM says XXXF, Turns OFF A/C, Have a 160 Thermo and tune
Today on my ritualistic Saturday morning cruise in my Z06 my A/C turned OFF. At first I thought maybe I had hit a button, then I could see the PCM LCD telling me Engine HOT, AC Turned Off (or something like that). The PCM LCD display says xxxF but oil temp is totally normal like 141 degrees.
My car has an 07 with 3001 miles on it a 160 thermo and it has zero coolant leaks. The engine feels cool to the touch at this time. So I unplug the ECT sensor and get the same error/issue. I plug it back in and I get the same error/issue.
This tells me:
1) No ECT sensor signal to the PCM
Which could mean:
Bad sensor
Bad harness
After reading a few different posts on this exact same issue and how this problem solves itself I thought it best to disconnect the battery and let the car sit for 10 minutes, reconnect everything and restart with the ECT plugged in.
This has (for now) solved my issue. I have also used HPTuners (friend has it) to reset the code and the problem instantly goes away.
Question: Has anyone else had this happen before? What resolved this challenge permanently?
My thoughts are:
There is some sort of routine that is taking place with the PCM and thermo and the PCM is being sensitive and thinking the coolant temp sensor is bad?
I could have a bad ECT
I could have an issue with my harness or worse a PCM issue.
