LS1 Ecu running non GM motor
Hi Guys,
Im chasing some help/info regarding LS1 Ecu's,
I have a 4.6ltr Rover V8 in my 93RRC.
The car currently runs a wolf ecu with a 4+1 crank trigger and has faclilties for a cam sensor if required.
The current system runs a 0 to 4.8v TPS and a Bosch/GM IAT and ECT sensors.
No Maf so would run an SD tune
Running 4 coil pack in wasted spark ( will an LS1 ecu support wasted spark or only coil on plug?)
Trans is 4 speed ZF auto. Mech/hydraulic controlled so no requirement to control the trans.
The car also has abs triggers/speed sensor so depending on the tooth count I would possibly be able to derive VSS from on of these (Does the LS1 ecu need VSS?)
What input triggers would the LS1 ecu be looking for? Is there a particular model/year ecu that would best suit the conversion?
Are you able to alter firing order in the PCM or would the cars wiring need to be configured too suit the ecu?
thanks in advance for the info guys:yay:
Luke
