i can not stand alone datalog my wideband with my mpvi pro. did i miss the memo or am i configuring wrong? i have my cfg that i want to use and it works fine with the laptop.
Are you using 2.22 or 2.23 (beta)? If I remember correctly, using the beta 2.23 release doesn't allow stand alone data logging at this point.
i am using beta. i am assuming it's possible with the production release. correct?
There was a beta release that didn't but it was fixed. I believe latest beta will work fine.
bill says not yet. thanks for looking guys.
Yeah I talked to our software designer about this about a week ago, he's currently working on the firmware update and he'll try to get this reenabled in the beta once the firmware is worked out.
Oh I see its only on newer units, right?
I'm on 2.23.248.
I can log now without the PC (I am SO happy this works now!), but cannot log the WB.
Am I understanding correctly that this is a known issue and will be addressed at some point in the future?
Yes, please Bill!
WOW I wish I had read this way before now, I don't have any hair left. One day I was able to do a stand alone and log the EIO inputs just fine and now nothing................
Any updates on this yet?
I need this................I hate going backwards
Thanks!
with your stand alone, you have to limit the parameters you are scanning. I cant recall how many are allowed in the MPVI. Then you have to write that configuration to the MPVI. The last couple updates ive gotten have been able to do stand alone if the configuration has been written to it.
Thanks!
What update are you using?
I just finished downloading the most recent update so I will try it today.
I still can't get it to work.............Phil whats your secret???????
According to Bill today
"Still working on it"
Thanks,
William Henn
HP Tuners LLC.
Well, it's not useless, you just need to have a laptop in the car connected to the MPVI logging data in order to use the wideband sensor. Not ideal at all, but not useless either.
I'm about to install a blower, and I'll need to log afr's which is even more critical with boost then NA, so my laptop will just have to go along for the ride.
aux's are still on the no list.
