OBD|II|2|fuse|ls1|swap|amp|scanner
For those of you who swapped an ls1 into your car what are you using? I've seen everything from 7.5-40 amps. I think something around the 7-10 amp mark sounds right. < 20 amps will drive a fuel pump for christ's sake, I don't think the HPT interface/OBD scanner needs that much current flow.:confused:
I searched and didn't find anything useful other than "my cig light fuse is blown". I checked the service manual for my 2001 acura integra and they run the OBD II port off the back up light fuse, which is 7.5 amps. I think I will run the OBD II port off of a 7.5 A fuse and see how it fares.
