i need to turn it off and my only options are
serial
pwm
none (but i cant select it)
serial
pwm
What are you working on ?
OK, I see you have a 2000 Fbody in your Sig....
I was told that Serial choice would disable the theft fuel enable...
I use 99 and 2000 GTP code and this has VATs disabled already.
Loyde
im get p1629 the security lights keeps flashing and car wont start
Quote:
Originally Posted by Nightrida
Did this happen after a flash to the PCM? I know there was some problem with the VATs on 1.5 and a email was sent out indicating for V6 users to download 1.5.1...
Loyde
What version of software are you using?
i went from 1.4.6 to 1.5.1
i never loaded 1.5 because of the email.
i am also having a problem connecting when trying the use the flasher but the scanner works fine.
You cannot use the VCM Flasher if the Scanner is open.. So close the scanner, then open the Flash to make the changes to the VCM.
Your going to need to detail more of your problem to figure out what is wrong in the VATs area.
Can you put the stock file back into the VCM and get the car started?
Why do you need VATs disabled on a Fbody that has a BCM to supply the VCM with the theft fuel enable signal?
Loyde
vats is cool now . one of the wires in the ignition switch had broken. so a new switch and a pair of keys and i am rolling again.
