Wide Band pre-release screenshots
Here are a few teasers.
http://www.hptuners.com/pub/nb.jpg
http://www.hptuners.com/pub/wb.jpg
http://www.hptuners.com/pub/nb-wot.jpg
http://www.hptuners.com/pub/wb-wot.jpg
You can compare on the fly how the narrow band O2's compare to your Wide Band input.
For users that do not have our Wide Band cable, you will be able to chart your narrow band O2's in the histogram as well.
These logs were created today on Horists 383 stroker trans am and an innovative LM1 setup.
It took mere seconds to hook up the LM1 output to our wide band cable.
This is all the info I can give at this time.
Enjoy!
Re: Wide Band pre-release screenshots
Oh yeah. I like it. Now, I have an LSU4 bosch wideband sensor. Do you connect up direct to the 5 wire or do you read in the converted data from the driver box?
Quote:
We use the converted 0-5v output from the controller.
I have an Innovative WB02 if you want another guinea pig. :cheers: ;D
I have the FJO but since they all use an analog output we are typing in vain. If it works with one it will work with all
kick ass :) Any eta? I cannot wait :)
Dave
This thing is awesome :) so much more accurate than my narrowband sensors... 2 wires and we were good to go, i just set my LM-1 to output 0-5 volts for 10-20 AFR so it was a nice linear progression
I can't wait to upgrade to this unit :) VERY impressive
so... anyone wanna buy my RPM converter for my LM-1? :D
So what widebands is this going to be compatible with. I'm running the dynojet wideband commander which also has a 0-5V output. Are we going to have to upgrade our cables? If so any Idea on cost?
Yes we prolly will have to update out cables and any WB that has a 0-5 v output should be compatible.
http://www.ls1tech.com/forums/showthread.php?t=198259
so.. exactly how its thing going to hook up???
and will it work with my AEM unit??
per aem's website:
"User-programmable 0-5v analog output included for use with data loggers and ANY engine management system"
I am pretty excited about this.. will it be a loggable paramater as well.. so you could get a graph with that and RPM ect..
that would be soo friggin money..
as per the pics, yep it is logged in the scanner and it will be available to view in histogram (pics), chart and table displays (and probably the dash) as well.
Anything with a 0-5V output will work.
;D AWSOME! now.. i would imagine i take that 5v signal and wire it into something.. what would that be?? i am just trying to figure out if i need another com port.. or whatever..
you have no idea how bad i need/want this feature..
Hmm, so what do I do? I don't have anything in the way of a wideband right now....should I get one? I was looking at the Wideband Commander. Will this negate the need for me to get WC? If so, when is this product coming out? I'm so confused.... ???
It will be a new cable with both OBDII and Analog inputs, the connection to your PC remains the same. There will be an upgrade program for existing users to return their existing cable.
Quote:
The cable is not a wideband O2 controller it just takes the output from one, you will still need to buy that seperately.
OOO, waiting to update my cable. 8)
I just ordered my LM-1 (Turbometrics, $314) so you
can commence to shipping the upgrade any old time
now ;)
any rough or even high estimate for the cable upgrades?
I think I am gunna want this for when I start tuning..
Same here!
I have the DynoJet WBC and it is a pain to run and log their (WBC) software and HPScanner at the same time...
Estimate on pricing for cable upgrade???
:cheers:
Out of curiosity on currant histograms then it reads the LT and ST fuel trims and on future 02 which bank is it pulling from or is it averaged between the 2?
