Re: May or May Not be a Bug
Have you turned the misfire detection logic donw on the PCM
I went into the DTC and upped all of the misfire settings. The PCM used to through a misfire code and it no longer does that. Is there another area to edit?
Kane
I was playing with another Ls1 cam'd car and decided to run the misfire configuration I setup to monitor the cylinders and again it shows #1 with a random misfire?? I have changed the misfire settings in the engine diagnostics is there somewhere else to make changes so random misfire code is not sent to the scanner? It does not do it with Stock LS1's??
Kane
The logic the pcm uses to determine misfires is kinda thrwon off with a cam esp ones that have some lope. Ususally most people set the misfires in the low rpm tables to 32677 or someting like that. This takes care of the misfire problem
