What's the benefit of the 12200411 PCM?
I currently have a 09354896 PCM from a '00 model year 5.3L truck in an off-road project of mine which is controlling the 5.3L/4L60. Today I was walking through the junkyard and noticed a '411' PCM sitting in a wrecked '02 Silverado. I've been in the LS-engine scene long enough to hear about the '411' PCM being the ideal one to have, but I've never understood why, so I bought it lol :D.
What's the scoop behind this PCM and why is it sought after so much? If there are reasons why I should swap PCM's to this model, what should I look out for as far as the tune goes (obviously doing a write-entire to upload my tune into the PCM but anything else?)? Is there any reason why this 411 PCM wouldn't work with an '00 5.3L, '01 4L60 and electric fans? Would I need to send my tune in to have anything unlocked?
So What Are The Pros to the 0411
I was wondering if someone had a numerical/bullet point list of pro's of the 0411 and some of the cans/cannots of the computer.
For example:
1) a) 0411 comes in 512kb and 1mb options... correct? What are the differences?
b) If so, what would work best with my boosted 03 S10?
2) a) Can I run a MAF setup with 2 and 3 BAR maps?
b) Would this require a custom OS? And if so, what is the cost? 2 credits, or paying someone to create it?
3) Does it matter what year of 0411 you obtain? For example, were the 0411's programmed with different options for different vehicles and years?
This one was just answered recently
4) The 0411 is a Blue/Red plug... Will the Blue/Green plug work with it?
ANSWER: "I have used Red/blue PCM's with Green/Blue connectors. You only need to cut the little tab on the connector to make it fit. Check wiring first
It works good"
Any input would be greatly appreciated. Thank you.
Ben C how do I get what you got?
Quote:
Originally Posted by
Ben Charles
For what its worth I am running a 2 bar Custom OS on my 411 ECU and I have disabled my VE table and tune purely MAF :cool:
Ben thanks for the input. I'm not looking for freebies, but I had a few questions based on what you stated above:
1) How does running full MAF and no VE affect the vehicle (Pros/Cons)?
2) Where did you get the custom OS? If you did it yourself, would you be willing to let me know how to do it? (Understand if you say no. :))
3) And, can your OS sustain up to 3 bars? (Thinking of the future. :D)
Definitely appreciate your input. Thanks.
