Are Pontiac GTP L32 vs L67 timing tables different?
I run a 2006 3800SC L32 engine and am using a 2003 PCM to control it.
When I compare the RPM to air mass timing tables I find that the 06 timing values (in the table that I discovered here) are far more agresssive than those in the 03 program.
This is what I have decided to try (the 05 timing numbers in the table below )over the 03.
http://i276.photobucket.com/albums/k...imingtable.jpg
Does anyone have any idea if these timing numbers will work on my L32 2006 GTP 3800Sc engine w 3.4" pulley and short stack intercooler? The timing numbers especially at the high air mass values are about 3* more timing than before.
