Question about DTC's
I have a 2006 Trail Blazer that I have a few codes on. By Googling the code's I assume I need to clean the throttle body but I still don't understand the fuel trims being messed up and no O2 readings. Any suggestions would be very appreciated. Thank you.
http://i31.photobucket.com/albums/c3...uce/blazer.jpg
http://i31.photobucket.com/albums/c3...ce/Blazer2.jpg
Anything you want to log you have to put in "Table Display", doesnt seem like you put everything there.
Next fuel trims lean is due to the LTFT at +~11% I would think.
TB could be going bad that is why you are getting a performace issue.
Seems you have an I6 in that? Your LTFT bank 2 show 100%, take those off of the table display and any part of the log.
Read the how-to's on setting everything up.
