NGK AFX mnitor sensor?
Well guys my sensor form my wideband is out when i connect it the only thing it shows its sen1, on the instructions it says to replace sensor.
I was looking them at the Ballenger Motorsports since i bought my wideband there and it shows 2 different ones, What are the difference?
Bosch LSU Wideband O2 Sensor ( UEGO ) with NTK/NGK Connector for NGK Powerdex AFX
http://www.bmotorsports.com/shop/pro...roducts_id/349
NGK / NTK Wideband O2 Sensor ( UEGO ) for NGK Powerdex AFX, OEM replacement & other wideband systems - NGK PN 24302
http://www.bmotorsports.com/shop/pro...roducts_id/352
one is a bosch and one is the NTK, I like the NTK sensor better.
however if you do some research, my 2005 honda uses the same NTK 24302 sensor, but it is available for under $100 ordered as a Bosch 15401 (NTK sensor in a bosch box)
Ryan
As mentioned, the Bosch P/N 15401 is the NTK sensor. You can get it at autozone.
So both of them read the same air fuel or one is more accurate?
In my experience the NTK lasts longer than a bosch and is a little more resistant to leaded fuels.
If you have the AFX can you run either sensor and the controller will recognize it? In other words, if you have an AFX with Bosch sensor can you replace the Bosch sensor with the NTK one and it will work?
