lean first gear
was tuning a holden gen 3 ls1 with ETC, heads/cam setup.
I switched to SD mode since his MAF is not working. disabled ltft's and using wideband to tune partial fueling and WOT.
I have a problem where 1st is always lean... 2nd and 3rd gear is fine though.
I have posted a log which shows IDC/injector pulse width increasing but still shows 1st gear lean. I haven't logged the wideband through the scanner, but i do see it with the lm2 hooked up in the offroad pipe.
You can also tell by seeing the o2 sensor voltage in the scanner.
Any advise?
your case is different.. in my case its the a/f ratio is 16's and immediately goes to 12's.
