doing a custom wiring thing..need about a dozen of the metripak connectors..
its the pin for the o2's...I need the ones for in teh o2 sensor connector not teh connector on the car
thanks if anybody has it
i dont have them but i might be able to get them for you. my supplier has a minimum order, so ill try and check it for you tommorow! i also need to know if you need the square one or the rectangle one!
I need the ones that are in th econnector on our o2 sensors....
not the car side...the actual O2 sensor connector..
I an going to make a custom wideband/narrowband conection to my car with the stock connectors
OK, I'll try and check on these for you tommorow, but be patient because the supplier I have found is slow in rturning calls!
Also, do you do any bench tuning? If so what power supply do you have, or what would carry the amp draw of the ECM? Do you know how many amps it draws?
lol, i know what you're making... :p
e-mail me with your address, and I'll send you some.
[email protected]
Ryan
you get my e-mail Ryan??
Question: Why not just lop off the o2 sensor & attach the length you need? Or: Are you making adapters & need quantity? Check out: Power & Signal
EC
I want to make it completely weaherproof....with no splices for better conections...
I have the conectors.I just need the pins..
power and signal wanted like $36 for a 100 pack..If I remember correctly...
and I need 12 pins..LOL...
not paying $3 a pin for what I need..LOL
Have you checked through http://www.samtec.com/ they have almost any pin or socket combination that you can think of. If you make the sample request look like a comercial(sp?) order they send out free samples fairly quick. Keep the qty. at 10 or less for best results.
I use this supplier at work for prototypes often and they just keep sending the requested trials.
I cant find any on there...
but lots fo RF stuff...thats a good linke for a whole other project I have going on..LOL
man i'm sorry i forgot about you needing these! do you have the crimp tools needed to put them together if i can get you the parts you need to make/build them?
I just need the pins....If you have connectors..I could use them..but I dont need them as I can bastardize a old sensor...
I can crimp..no big deal...
To purchase such a small quantity I would just go to any GM Dealer
Metripac 150 series Male (Sealed)
Terminal PN# 15326269 located in Tray 19 of the GM terminal repair workstation (J38125)
HTH
WopOnTour
PS> The female 150 M/P sealed is Terminal PN#: 12191819 / Tray 8
is there a catalog where I can look at the spread apart view like GM has when you go in for parts?? ...theres a few other things I need and would like to find the part #'s so I dont have to deal with the idiots around here....LOL
pm sent
