hello did a read friday night on a f350 with 5.4l. read out alright but gave ome index out of bounds.
will these be supported in the near futute
Attachment 41128
Attachment 41128
Its already supported in 2.24
Is it possible there may be an issue with the template? I'm getting a lot of erroneous values in the editor and some blank "Switches"
Using version 2.24.227
anything is possible, I can't open files on this pc but if you send me an email reminder I can have a look in the morning on my work pc.
Took a look at the file and to me it looks like the file in the pcm is just screwy, I'm pretty confident each and every table & switch in that def isn't wrong ;)
ya read was from f350 didnt think it was even going to work, but read out just doesn't look right and gave error messages
just down loaded latest version and still lots of blank switches
tokymon its likely NOT a software issue on our end as stated in my post last night. I'll have our ford engineer take a look when he has a moment though as I don't have a stock file with that operating system to test.
I would get a Fresh read with the Latest Software you have now and see if it errors when downloading and if it is still corrupt.
Wondering if it is possible that with older software that did not recognize the Truck correctly that it may have corrupted file?
Not sure if that possible or how old your software was with original read.
this is a stock truck never been tuned before.
thanks Tokymon I'm having our ford engineer look into it.
Try redownloading & reinstalling this mornings build 2.24.235 or newer
will do. wont see truck till tonight.
Using the file he posted above, that looks much better.
Yeah the def got mixed up with another one, switched them around and all good again :)
It Worked. :cool:
thank you
