1 Attachment(s)
ZR1 injector data in 0411 PCM
I did the conversion from pressure delta to VAC KPA. Then copied corresponding columns and interpolated in between columns. Just wanting someone to check my work and make sure I didn't mess this up. The data is going to be used by a friend in his turbo LS1 S10. The OS I used to work this is a 2001c5z.
Also Greg Banish was saying that these injectors have a different spray angle than regular LS injectors and the transient tables would need tobe adjusted to account for wall film effects. I need an idea of which tables to adjust for this. My other idea would be to change the EOIT and spray with an open intake valve instead.
Jim
Attachment 47561
