Trans Torque Management Settings
I've never really understood the following Transmission Toeque Management parameters and what they really do. Can anyone help shed some light on any of these?
1. Diff Score (Enabled/DIsabled - Master enable/disable for transmission differential scoring torque reduction calculations). What the hell does this really do - what effect does it have on the car while driving?
2. Stall Torque Mgt (Enable RPM/Disable RPM - If Engine RPM is greater than (or less than for disable RPM) this stall torque management mode is enabled). Again, what effect does this really have? I've read that it will not allow the engine RPMs to exceed the Enable RPM while the brakes are applied - but isn't that really what "Brake Torque Management" does?? How is this different than brake torque management?
3. Under the "TCC Limit" heading:
- Tq Reduction (Enabled/Disabled - Master enable/disable for transmission TCC limit torque reduction calculations). Same as above, what does this actually do?
- Max Torque (Maxium TCC Limit Torque. Should be higher than maxium engine torque when TCC Limit is disabled). Once again, no idea what this really does.
4. All fo the settings under "Limit TqMgt" - While I understand what the "Tip-In TqMgt" and "Flare TqMgt" setting do, I have absolutely no idea what these ones really do. Anyone?
Thanks for any insight you can provide on any of these!
