2 Attachment(s)
Updating LS2 tune (E67) with stock LS3 Injector Data, but x axis values are different
I have a 69 Camaro with an LS2 behind a 4l70e out of a 2008 TBSS. Originally we slightly modified stock 2008 TBSS base tune adjusting the shift points, power enrich, ve and spark tables. The vehicle ran fine for several years like this, but the go fast bug bit me and I recently installed cnc ported LS3 heads, new cam (227/235 .640/.647) and a stock 2010 Camaro SS intake/injectors. Surprisingly, even with the upgrades the motor idles and runs well with the original tune, but I know the tune needs to be updated before I drive the vehicle much.
I started to update the injector data and grabbed a copy of a stock 2010 Camaro SS with automatic base tune, thinking I could copy/paste the Injector Flow Rate vs Pressure Delta & Injector Offset vs Pressure Delta vs IGNV table values into the corresponding LS2 tables.
However the range of values on the x-axis are different. Both tables have 33 columns, but the LS2 x-axis goes from 18.6 to 92.8 and the LS3 x-axis goes from 18.6 to 111.4. Comparing the x-axis on both tunes there are 7 column header values that match. Do I just take the columns that match and plug the associated values into the LS2 tune, then interpolate the rest of the values? This seems logical to me, but then I'm a newbie when it comes to tuning and don't want to find out the hard way that I am wrong. I am going to copy/paste the Pulse Width Adder table from the LS3 to LS2 tune since the x-axis values are the same.
I have attached a copy of my tune and the 2010 Camaro SS tune I downloaded from the HP Tuner repository. Any help with this, or other suggestions on next steps (tuning) would be appreciated.
