VCM Scanner AU Ford Update Thread
I have an update in the works that will add the following DMRs to the FG Falcons. If there is something you want to see that is not in this list. Please let me know ASAP. Less work for me to add it now, than it is months later.
Code:
LOAD
Cam Angle
MAP per Airmass (Current)
MAP at Zero Airmass (Current)
Manifold Air Pressure Sensor
Knock Retard
Inj. Pulse Width
Manifold Charge Temp
Average Air Mass
Borderline Knock
MBT Advance
Idle Adapt (STIT)
Desired Boost
Boost Error
Wastegate Duty Cycle
Desired Brake Torque
Engine Brake Torque
ETC Vacuum
ECT Throttle Angle Error
ETC Effective Throttle Area
Trans Output Shaft RPM
Trans Current Gear
TCC Slip RPM
TCC Applied (flag that shows if the TCC is locked)
Throttle Angle Source
Fuel Source
Spark Source
Idle Speed Source
Torque Source
