A/C Pressure Sensor on PCM 411 2002 express van tune
Has anyone ever ran across this situation. I have a 411 PCM with a tune from a 2002 Chevy Express Van . Also I have a Vintage Air A/C system installed in which I wired to use an A/C pressure sensor (22664328) in order for the PCM to control the A/C unit . I changed my AC Type in the tune to analog , The fans and A/C clutch relay comes on when the engine is running, everything appears to work OK except for the A/C pressure Sensor. The fan and A/C clutch relay works whether or not the A/C pressure sensor is installed . Can't figure out why the PCM is not looking for the output from the A/C pressure sensor. The A/C pressure sensor is wired C2-14 red , C2-57 violet , C1-45 gray , A/C clutch relay coil C2-43 and relay contact to C2-18 just like the 2002 Camaro. MY understanding is the PCM should not turn on the fan and A/C clutch relay unless it see the output from the A/C pressure sensor and the engine is running at 550 rpm.
Any help is appreciated.
