ls3 injector data for 01 trans am ecu
I found the ls1 to ls3 spreadsheet that has the yellow and green data and u can enter info and it change it from the stock ls3 info to ls1 info but the info it spits out I cannot enter that into the tables in my tune.. its like it rounds up or has a limit, Is there something in my settings I have to change for me to be able to enter the values? like for instance the min pulsewidth I cant go as low as the ls3 injectors require even converted to the "ls1" converted table the number is lower on the spreadsheet then i can enter on my tune table, im newer to this tuning stuff so im still a newbit and im making a sd tune but I discovered I have ls3 motor and injectors and the data in the injectors is not right and its running crazy rich... HELP! lol i been searching but I cannot find anything relating to this I cant find a real answer
