I have reviewed all the variables for my 2.2 L61 and it seems that there are a lot less tuning parameters for the Ecotec than lets say an LS1.
Is this because they don't exist or because support is just limited in the VCM at this point?
They don't exist, different engines have different parameters. Which ones were you thinking of in particular?
Well, I am finding it's a pain in the butt everytime I reflash the engine needs to relearn the trim cells especially park/neutral and drive/reverse. It's a little bit tough for the first few miles when the engine stalls out when you slow down to an idle and you lose power steering/brakes, ect. :bigshock:Quote:
Originally Posted by Shifted
I have read some simular posts about the issue and people refer to tuning variables that don't exist for our code.
Based on my experience with the cals, I seriously doubt the extremely limited # or parameters that I have seen available in the J versions of the software, compared to the other platforms, is due to anything less than that they simply haven't been mapped out or decoded yet.Quote:
I hope this does not remain the case forever. I hope it will improve with time.
The software does give us a ton more tuning capability than most will usually need, but I want more control over things like EGR flow, etc.
who needs EGR when you can..... disable?
No EGR on my car :)
the 4cyl code does have less parameters in it, however there are a few extra things that will be added as time goes by. If I had added the same amount of params as we have for the LS1 (of which maybe 5% actually get used) i'd still be typing emails saying we're releasing any day now ;)
Bottom line is if you are stuck on an issue let us know at support and if there's parameters that can be added to fix it then we'll add them.
Chris...
anything added in the new update?
still trying to figure out how to use the EGR or EVAP drivers to power a N2O setup ;)
