My 07.5 Ram Cummins unlocks the converter every downshift then re-locks shortly after the downshift. I would like to have the converter stay locked at all times. Is that a feature that can be added?
Thank you.
Steve
Thank you.
Steve
post up your tune scanned with the latest 3.2 editor, pretty sure you have the ability already.
Hmm wont let me open the file. Is it locked by chance?
Looks like you have everything you need to make the adjustment, that said really need a good log to determine the right changes to your apply and release speeds. I have a feeling it will just be the TRANS>Auto TCC>TCC Apply table which sets the minimum time you need to be in each gear before itll lockup, basically no matter what you do if that table has anything other than a zero I would guess itll always force an unlock.
If that works I will be super happy.
I tried changing almost everything in the TCC parameters with no luck. The only parameter that seemed to make a difference was the Min Time in Gear. Zeroing that table seemed to make the TCC engage without any delay but it still unlocks on every downshift and only locks above 35 mph.
Steve
need a log.... cant help much. And need a copy of the tune you attempted to use.
